Thank you, this is most helpful. What PSI changes under manifold would you expect from temperature changes? I will ask the PB to check again since I understand the skimmer should have no pressure loss. I am confirming ours look like the one in your picture.In reality no pressure loss from the skimmer should be noticed and if their is it’s an easy fix. The only pressure difference should be from the temperature changes due to the plumbing being exposed in the trenches. When their is a difference and no recovery that would also indicate a possible leak.
The plumbing system is designed to have no leaks at all, not even a single drip from glued joints or threaded cuplings.
The faucet is typically on the manifold only and not on the skimmer loop.
My concern is that the PSI change (32 to 27 over 3 days) cannot be only due to temperature changes only (also note we are in generally moderate temp of high 85, low 65s).
