Hi All,
I am a new pool owner and have so far tested the pool twice and added chemicals once, all following the TFP methodology.
In between the first and 2nd test I added acid, calcium and stabiliser.
Here are the numbers from my latest test:
FC 11 (previously 5.5)
ph 7.4 (previously 7.8)
TA 100 (previously 75)
CH 225 (no change??)
CYA 80 (previously 30)
salt not tested this time
So all in all that looks pretty good to me. I will reduce the SWG % to drop the FC a bit.
What do you think about the TA? Is that too high now?
Also even though I added calcium, the CH test did not increase. Is this an issue?
I added 50% of the amount of calcium suggested by pool math.
I guess i just need to add more.
