I have an infinity edge pool with a concrete catch basin on all sides.
See attached photo from a 2nd floor balcony with the deck pulled up.
Under normal operation, the infinity edge pump is always running and spilling over.
The automatic pool filter was putting a lot of water in the catch basin daily. Nearly an inch a day which I believe is about 70-100 gallons (estimate based on my Flume meter). I thought I had a leak in the suction lines, of which I have 2 in the catch basin. One for the Edge Pump and one for the Filter. I thought something was wrong with both these lines, but according to the leak detection company, they passed a pressure test. I was not available that day to see what they did or verify they tested correctly.
I then plugged both lines (picture attached) but was still losing water at the same or similar rate. I then did a Bucket test for sanity. Definitely a lot of evaporation in these low 90s heat here in Southern California, but not enough to explain the amount of water loss in the basin. My bucket did not lose an inch of water a day. Nowhere close.
This water loss happens (about an inch over 24 hours, give or take)
So now I believe that the catch basin, made of concrete, was just not sealed correctly and that my excessive water loss is not specifically a leak somewhere but the fact the concrete is not water-proof. I have attached a close-up of the catch basin. I don't know how to tell if it was sealed or how well it was sealed.
This has been a real bit of a nightmare for me. I have spoken to multiple leak detection companies, the pool builder, the "pool guy", other "pool guys" and so on and so forth. I have repeatedly gotten information or advice contradicted by someone else's information or advice. Nobody seems familiar with this type of pool (infinity edge on all sides, catch basin on all sides, catch basin with 2 section lines that go to two different pumps, etc., all).
Hoping TFP can take a look and offer any thoughts on what I can look for to see if the catch basin is sealed correctly, or some other testing method I have not considered.
I have attached some photos of the pool, the catch basin, and one of the two suction lines in the catch basin that is currently plugged.
Thanks for your time. Let me know if I can provide some better details, please. This is my first post as I've never had a pool like this and never had these sorts of problems to deal with.
Vahn
- about the same rate if I run the pump or don't the pump and
- if both lines are plugged or either line is plugged, or neither is plugged
Vahn
