I've try finding a solution a similar problem with search but hard to find with my situation. .Any help is appreciated.
So, when I backwash or have it on Recirculation, I see tons of suction at the skimmers as well as outward flow back into the pool.
However, when 2 mins of going back to filter, I see it drop in both of suction at the skimmers as well as out back into the pool.
I have a nautilus FNS, Diatomaceous Earth Filter. When I turn the filter on, it says pressure is around 25.
I also tried backwashing for awhile (where there is tons of suction) thinking that would help clear it up, but within two minutes of back to filter - same thing, not a lot of action.
The pool is green would like to try to figure this out.
P.S. - I have the booster pump for vacuum. that is also not moving the vacuum when I turn it on. (polaris)
Thank you.
Brandon
Thank you.
Brandon
