- Jun 1, 2018
- 16,025
- Vinyl
- Hayward Aqua Rite (T-15)
Ok. I got it. Now what? Phew that was a challenge, eh? Raise by.6. What does that mean? Also I didn’t put in that 12,5 numberTry effects of adding in the hamburger menu
View attachment 425540View attachment 425541View attachment 425542View attachment 425543
Use the searchto find your swg or just put in your #/day if u know it
This means running your SWG running for 12 hours @ 12.5% power will raise the free chlorine level in your pool by 0.6. At this time of year, you want that 0.6 to be 4.0 (ppm of FC daily).Raise by.6. What does that mean?
ok. I read your post 3 times. but i Only run my pump 12 hours a day. So if I understand right IF i ran my pump 17 hours a day, then my SWG should be turned to 60? am I right about that? Just want to make sure I am reading it right. Also, with my old SWG that was undersized for my pool, I never changed the run time. I find this interesting. BUT I am definitely going to do an OCLT to be sure. My FC has never dropped below 3.5 tho....but you never know. Thank you Very much for your patience.This means running your SWG running for 12 hours @ 12.5% power will raise the free chlorine level in your pool by 0.6. At this time of year, you want that 0.6 to be 4.0 (ppm of FC daily).
Your first post indicates you run the pump 17 hours per day. Here is a screenshot showing 17 hours @ 60% will raise FC by 3.9 ppm. This is probably a good start.
I'll once again recommend an Overnight Chlorine Loss Test to rule out algae.
Correct. That would increase FC by 3.9 daily.IF i ran my pump 17 hours a day, then my SWG should be turned to 60
Here's the screen shot for 12-hour runtime. 85% will increase FC by 3.9 daily.Only run my pump 12 hours a day
