turned on my pool today for first time this year
pressure in the cartridge filter went up past 20 and then the water output from the filter blew off the input pipe to the heater and drenched me
the company did not cement it on well but it did last for 6 seasons without a problem
tried it again with the waste valve partially open and kept the pressure to 15
no water coming out into the pool so I think the water cannot get through either the bypass or the heater for some reason
is it possible to trouble shoot the versa flo
my heater came with it installed can I remove it and run like a regular heater
a versaflo replacement is over 500 dollars can dollars
can they be fixed
thanks
franklin
30000 gallon pool with attached overflow spa
main, spa polaris and waterfall pumps
jandy controllers and jxi heater that is about 6 years old
300
can they be fixed
thanks
franklin
300
