I had a problem with my Spa not bubbling. Checked the Jandy valves and they seemed ok at first. Went out this morning to put the Aqualink RS into Time out and proceeded to test the 2 valves. Both worked when using the dip switch but then the return valve stopped at one end and it wouldnt move back again. I tried testing the valves using the buttons in the panel, the Suction worked but the Return still was stuck. I tried a couple more times and the Suction stopped working. Now I am scratching my head so I switched the valve connectors inside the Aqualink and nothing. Took a closer look and noticed all lights were now off inside the Aqualink RS. I took out the 2 screws and dropped the front panel down, noticed the 3.15A fuse is blown.
While I am waiting for Amazon to ship me a box of fuses, what else should I be looking for? Bad microswitch? Shorted wires? This system is not even 2 years old yet.
