- May 13, 2020
- 91
- Plaster
- Pentair Intellichlor IC-40
So I just started taking over my pool maintenance from the PB a few weeks ago. I’ve been having some issues with the PH staying pretty high. But aside from that it’s been fine.
Recently my Chlorine was really low. (.5 ppm), checked the SWG and all lights were green and running fine. I usually keep it at 50%. I turned on the superchlorinate feature and after 24 hours it didn’t go up much. Called Pentair and they said to get water tested for Copper, iron, nitrates, magnesium and phosphates. I took the water to the pool store and they don’t test for all those minerals. They did test phosphates and it came back at 2000 ppb.
Of course they sold me a bottle to bring down the phosphates. But I haven’t done it yet. I ordered my own test kit and I want to check it on my own. Also because my son is in town and using the pool all day.
Aside from that I am having issues with my TA staying high. My CH is at 300 and I was wondering if I should increase it.
CYA is at 30, pool store tested and showed it at 40. Pool store recommended 4.7 lbs of stabilizer. But Pool math calls for 2 lbs. 8 oz of stabilizer.
I ordered 7 lbs of stabilizer and will start with what PM is calling for.
Any opinions on how to proceed? What should I tackle first? Do I keep adding acid to 7.0 then bring the ph up and keep doing the same process until my TA is in range?
I attached a copy of my local pool store report. My test results are on Pool Math.
