So I have a 500 gallon hot tub that I inherited from the house I bought.
fill the hot tub and install SmarterSpa chlorine generator. So is a salt water hot tub?
I haven’t shock it yet... so if I were to shock it, what product would I use? Is a salt water setup, so I use product that is design for salt water?
i am using AquaChek TruTest Digital Tester. I assume they are not that accurate. The first time shows my CL and pH is ok but alkalinity is high at 166.... I guess I need to add something. One of the pool supplier in town mention about a product that will lower alkalinity without lowering pH, is that the way to go? Or should I get pH reducer and than raise pH later?
I need all the help I can get. Thank you on advance
