The trick is to Maintain until clear. That's the hardest part for a lot of folks. Clear is when you can see every little detail on whatever is on the bottom of the deepest part. I usually suggest a quarter dropped in the deepest part. If you can tell heads or tails, you're good.
Here is an example: Cloudy pool
The fact that it dropped that much overnight means it's still working on stuff. As you know from the SLaM instructions, more than 1 ppm lost overnight is considered significant.
You have been brushing often, right? At least once or twice a day?
