I had the same issue with my pump. See the thread below:My other issue is in my VSP pump, if I have the speed set anywhere below 2500, I do get decent size air pockets/bubbles in the lid/pump. With that, I do see some bubbles (doesn’t seem like a lot) coming out of 1-2 return jets. I covered the 3 way valve, exposed piping on the valve, and the pump lid area with shaving cream, but didn’t see anything get sucked in or any movement. Hopefully there isn’t a leak somewhere. I no longer run it 24/7 and I have checked in the morning before it kicks on and it is full of water. (I have three stages, stage 3 kicks on for 2/3 hours at 2800 and the air pockets go away)
Air at the pump
I’m not sure what it’s called but it’s where the small strainer basket is connected to the pump. Mine keeps getting air in it. Is this normal? It only gets air when I run the VSP at a lower speed (I usually run at 50%). If I run faster, the air is pushed out and it looks normal again. Hoping...
