I’m not sure what it’s called but it’s where the small strainer basket is connected to the pump. Mine keeps getting air in it. Is this normal? It only gets air when I run the VSP at a lower speed (I usually run at 50%). If I run faster, the air is pushed out and it looks normal again. Hoping this does not indicate a leak. There is no leaking anywhere above ground on the equipment pad. Not sure if the issues are connected but I’ve also noticed air coming out of one of my jets sporadicly. Not sure if it matters, but it only appears to come out of the last one in the line.
