So I just installed a Pool Factory Intrepid Aluminum Oval pool 12 x 24 x 54. Everything looked to be going fine, until this storm from Elsa hit, and the area around the pool got flooded (we were in between a finished pool and the backfill process). The pool is buried 12 inches below grade. Anyway, long story short the inundation of water around the frame of the pool caused sand to be washed out above the buttress supports that lay on the ground (attached to each other on opposite ends by metal straps). The divots I guess you can call them are about 5-8 inches wide, and they seem at least from the above to be about 2-3 inches deep. So in a way I'm extremely disappointed since this happened literally days after the pool went up. Anyway, here are my questions:
1) Repairing the divots: Do I simply drain the pool, remove the existing (practically new liner), fix the low areas, and re-install liner, or is too late to re-use the liner if I uninstall it.
2) The intention was to leave the backfill for after the electrical bonding, but is it required to have the electrical bonding at the same level as the base of the pool, which as I mentioned is 12 inches below original grade? If not, can I immediately backfill now after the repair and a separate trench will be created for the bonding?
3) I would like to somehow have a drainage system installed, or very good way to shed the water away from the pool walls after I backfill. Any good recommendations. The pool is in the yard one side, and the next to house on the other side, about 14 feet away, separated by a future deck that will be at equal level to the pool itself.
One additional question, unrelated to the sand issue above, but concerning the buttresses installed:
1) Is it normal for the vertical sections of the buttresses to be perfectly vertical, or are they by design meant to be a few degrees off inward/outward? Essentially is there anyway, to know if the buttresses were installed incorrectly by looking at them from the side, or possibly from inside the pool?
Thank You,
Amado
Thank You,
Amado
