Clearly Scott is an engineer........... Lots and lots of detail and loves him some automation & iPad apps!
That will keep you busy Shuck.. hehe
it's worse than just being an engineer. I'm an engineer who has worked in quality control.
I preferred to push the pool builder harder on quality then on timeline, it was winter time. I kept repeating to them that I wanted whatever it took to get in a low maintenance, energy efficient pool. I had a good relationship with the pool builder throughout the process and feel that we have a very low maintenance pool.
My advice, spend the time becoming knowledgeable on the products they will be using. The installation of a pool is a lot like a partnership. They do the work but you have to make sure you are getting what you want, and if not, speak up before they are unable to fix the problem.
JXiVFKIT | VersaFlo Bypass Accessory Kit for JXi Heaters |
Depending on how old your heater is, they have a new bypass for the 4K heater. Increases the life of the heater and also the amount of head loss. So far it's worked great. It works with the JXi heater that you have.
JXiVFKIT VersaFlo Bypass Accessory Kit for JXi Heaters
One other note, gocubs418. Did they install the Savi LED lights? We had to have them all replaced, started changing colors rapidly, it's a known issue. There is a 2 year warranty on the lights. The older ones required pulling the entire wire through, the new ones only require replacing the cartridge (no wire pull). Something to keep an eye on while they are still in warranty.
I feel pretty confident that your PB is HCP.
They will have to tear down parts of the fence to get their vehicles into your yard. They took down the entire section of fence along the alleyway to get the excavator and bobcat in.
