Just getting started, here's my plan, am I doing the right thing?
brokenblinker
26
San Jose, CA
We've been checking FC every two hours or so.
In the first couple hours, we went from ~28ppm to 23ppm
In the next couple hours we went from ~28ppm to 25ppm
Do these levels seem reasonable?
brokenblinker
26
San Jose, CA
Pool has made remarkable progress for 24 hrs! I've been checking and readjusting to SLAM level FC (28ppm) every 2-3 hours. Nice and blue now and just a bit cloudy. I can easily make out the drain and imperfections on the bottom of the 6ft deep end.
We dropped from 28ppm to 23ppm overnight. I just tested again a few hours later and had dropped from 28 to 26. Sun is out now, so I'll take future results today with a grain of salt.
I also tested combined chlorine this morning and got 0. Is this expected?
brokenblinker
26
San Jose, CA
The pool is now crystal clear! But, I still seem to have dropped FC 3ppm (28->25) overnight, so I guess we are not done with SLAM.
I have not bothered cleaning the filter yet. The filter pressure has stayed pretty constant at 10-11 PSI since starting.
Oly
1,692
Fresno, CA
Look for areas of your pool where algae may be hiding. Common spots are light niches, ladders, wier doors, autofill plumbing, water features, pool toys, etc.
brokenblinker
26
San Jose, CA
There is very little algae still left on walls, its just hard to scrub in the very corners from outside the pool (will need a smaller brush and get in).
Is it ok to leave these very minor areas till after, when we plan to get in the pool anyway?
brokenblinker
26
San Jose, CA
(No prior experience with pools).
I had heard that up to SLAM levels was safe, but because we are maintaining constant SLAM level FC, I was concerned whether a minor FC measurement error (for example, actual is 31ppm instead of 28ppm) would still be safe to swim in.
mknauss
33,824
Laughlin, NV
Test FC before you get in. It is not hard and fast, but we know the active chlorine level at SLAM level for your CYA is less than with 1 ppm FC with 0 CYA.
Rinse off after you get out.
brokenblinker
26
San Jose, CA
Welp...We brushed everything off. Pool is crystal clear including all walls.
I decided I should clean the filter, and at the same time, replace the drain plug which has had a slow leak, so that we could pass overnight test.
I got a 6 point hex wrench specifically for the pre-2005 pentair filter drain plug. Well, the leak is faster now, but my wife and I could not get the filter drain unstuck no matter how hard we tried. The wrench is just slowly rounding off/popping off the hex pattern.
Guess we'll have to get some professional help and start over (since the leak is enough now that I don't really want to run the pump all the time).
mknauss
33,824
Laughlin, NV
Keep your FC levels up and brush to mix it in.
Can you fill out your signature? If we knew what type of filter you have, maybe a member would have an idea to help you out.
brokenblinker
26
San Jose, CA
Welp, fortunately a pool repair service had someone available that was 10 min away from me.
They came out, were also unable to open the drain valve. The valve had cracked in the center, and that's where the leak was coming from (I bet someone over tightened it long ago). This is also why the leak got faster after we tried getting the drain plug out, it widened the crack.
They opened up the filter and drilled it out from the inside (I cleaned off my absolutely gross filter cartridges while they were working on that part). I was amazed at how much green those filters were holding.
Pump is back running, with much cleaner filters, and no leaks (actually there's one on the union on the pump outlet, but it only leaks for ~15s when the pump starts up, then goes away).
Reactions: mknauss
brokenblinker
26
San Jose, CA
Also, whether we pass the overnight test or there are more learnings, I want to say such a genuine thank you. I felt pretty hopeless picking everything up fast enough when we moved in and had other house projects going on, but I've learned so much.
Reactions: mknauss
Oly
1,692
Fresno, CA
That is a beautiful transition pic. :goodjob:
I have never pulled the plug on my Pentair canister. I use a shop vac from the inside to clean the bottom. I've read many stories like your experience with that filter plug.
brokenblinker
26
San Jose, CA
We passed the OCLT last night, and after the drain plug replacement, it is now bone dry under our filter (used to always be damp/wet).
What FC would you let it drop to (I know 8-10 is recommended for our 70CYA) before feeling safe to let, for example, our little baby splash around (with many safety precautions).
