- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
Not very well. Last night about 9pm I got it up to 12 and this morning it was down to 4.5. I then brought it back up to 12 around 10am and just checked it now at 11:15 and it's down to 8.How is your chlorine holding?
CC is at 1.5. Turned pink and took 3 drops to bring back to clear.Might as well test CC when you test FC
This is extremely reassuring to know the dropping numbers are part of the process. I thought I was messing something up because I couldn't keep my numbers up!Now it's a matter of "Maintaining" the FC level. In the early part of the SLAM Process, chlorine gets used quicker as it is fighting more organic material. Eventually that large drop should slow down. In the meantime, test 2-3 times a day or as much as needed to gain confidence the FC is beginning to hold based on your chlorine additions. Follow the SLAM page and make sure you brush often and inspect any areas of your pool that could hide algae.
I waited until after 9pm to do the last water test and add bleach thanks to your post ?Also, you will get the most killing power out of your chlorine at night so dose it appropriately so it can kill the algae and bacteria without competing with the sun.
Oh ok, I see. I thought vacuuming to waste with a cartridge filter meant vacuuming with it not flowing back into the pool but out through a waste hose. I did figure out through my wanderings of the internet that backwashing is not done with a cartridge filter. That was an aha moment for me.Normally with a cartridge filter you cannot vac to waste. And once the algae is dead, it is just as well to vac to filter.
When your filter pressure rises by 25% over clean pressure, clean the filters.
I have valves for shut off on both the outgoing hose and inlet hose. I turn off the inlet valve and open the cap on the back of my filter housing. That way the water flows out instead of back in. I have attached pictures of my set up. I close the valve on the right and open the hole on the back with the black screw cap.Is your equipment pad plumbing set up so you can vacuum to waste? That is not normal for a cartridge filter system as you do not have a multiport valve.
I've attached a surface picture, a look down into the water that shows lots of organic floaty stuff, and a picture of the water flowing back in looking cloudy and dirty. The water flowing in filthy is what led me to vacuum to waste prior to my original post here.Is your equipment pad plumbing set up so you can vacuum to waste? That is not normal for a cartridge filter system as you do not have a multiport valve.
You know, I thought about doing that... so maybe I check every hour or 2 during the day and adjust the bleach.Keep at it! You can get this done. The more often you can test and get it back to SLAM levels, the better.
Quick question, should I leave my ladybug vac running or should I only vacuum manually?Keep at it! You can get this done. The more often you can test and get it back to SLAM levels, the better.
I'll check that right now. It has been more than 48 hours.Also when did you add the CYA? I would test it again if it’s been more than 48 hours. Just want to be sure you are holding the right FC levels.
I’m not familiar with that vacuum so I can’t answer that one. >.>
My CYA is at 20. I should add more to get to 30 or 40?Also when did you add the CYA? I would test it again if it’s been more than 48 hours. Just want to be sure you are holding the right FC levels.
Oh gees, Ladybug isn't even in the name, I don't know why I called it that.Looks like a suction-side vacuum. I’d let it run so long as you keep an eye on the baskets / filters the water goes through and clean often as they get clogged.![]()
