- Apr 25, 2015
- 109
- Plaster
- CircuPool SJ-15
So this season, my spa jets are not working correctly. They only output a flow similar to our pool jets, not nearly enough to create the usual bubbling action. The spa pipe on our equipment pad is not sucking in air either like it used to. Not sure what the issue is. I emptied half the spa water back into the pool and noticed that when some of the jets were above the water line, they were not very strong, but when the water line dropped below all the jets, there was a noticeable surge in the water pressure coming from them. I thought maybe draining some of the water had cleared an obstruction or equalized the pressure or something. So I refilled the spa hoping that had solved the problem...but it did not. Can anyone guide me into fixing this or what issue I should look for? Thanks.
