Hi,
the jets balls in a swimming pool, when the bezel is tightened the ball inside doesn't move. When it is loosened, the ball moves.
what is the proper way to keep the equipment running. Does the bezel have to be tightened so the ball doesn't move, or does the bezel need to be slightly loose for the ball to be able to move around?
thank you,
g3lo
thank you,
g3lo
