Hi,
We have an inground pool with a Pentair VSP pump, Hayward sand filter, gas heater, salt water generator, and 5 port caretaker pop up cleaners in our pool. The pool is a 34,000 G pool and has the Iaqualink automation setup. The pool turns on at 6AM, shuts off at 9PM, the pool lights go on at 8PM and shut off at 10PM, and I can control the pool pump, lights, heater, and the Jandy valve actuator (for the pool floor cleaners or waterfall) with the app. It all works, and I dont really use the wall panel in the house, but it is nice to see the pool and outside temperature as we walk by.
The inside the house wall control panel died, and the pool service person asked me if I needed to replace it. He said that since you control it from the app, why replace it? There is no fancy upgraded model to the 80's style 4 button RS 4 panel, other then an 8 and 12 button panel. Is there a newer panel with a touch screen that you guys recommend, or should I just uninstall the panel and mount an Ipad mini there with the iAqualink app?
Any advice is appreciate.
Thanks again.
Manny
Thanks again.
Manny
