I've got 6 Jandy single speed pumps with my pool setup and looking to replace *3* of them with a VS pump. I have a Jandy AquaLink RS-P16 Rev T.2 (2 separate control board/boxes) that controls everything. (I'm not looking to use any kind of JVA or reducing the # of pumps).
My two pumps under consideration which I know will work with my Aqualink RS panels are:
* Jandy VS e-Pump 2.7HP (VSSHP270DV2A)
* Pentair Intelliflo VS (011012 - discontinued?) *or* Pentair Intelliflo VSF (011056 - current?)
Specific questions regarding the Pentair pumps.
1. Either the Pentair Intelliflo VS (011012) or the Pentair Intelliflo VSF (011056) would both work with my Jandy AquaLink RS-P16 Rev T.2, correct?
2. If using the newer Pentair Intelliflo VSF (011056), I'd have to set it for VS only (not VF), correct?
3. The older Pentair Intelliflo VS (011012) is a discontinued pump at this time, correct?
4. The older Pentair Intelliflo VSF (011056) is a 1.88hp pump, correct?
5. The newer Pentair Intelliflo VSF (011056) is a 3hp pump, correct?
6. I would need (3) RS-485 cables from Pentair to connect the Pentair Intelliflo VS (011012) or Pentair Intelliflo VSF (011056) to the RS-485 interfaces on the Jandy AquaLink, correct? If so, any idea on the part number for Pentair RS-485 cable?
General Question.
1. It looks like I will need another RS-485 multiplex board for my Jandy AquaLink RS unit because I only have *1* open RS-485 connector, this is regardless if I go with Jandy VS ePump or Pentair Intelliflo VS, correct? (see attached screenshot) (yes, I read you can "double up" on the RS-485 connections and have 2 devices per connection but I'd rather not do that)
2. This AquaLink Multiplex Board or this https://www.amazon.com/Zodiac-6584-...&sprefix=jandy+multiplex+board,aps,144&sr=8-2 seems to be the right one, correct?
Thanks for answering my above questions!
General Question.
