- Oct 17, 2020
- 26
- Plaster
- Hayward Turbo Cell (T-CELL-5)
Hi, I have two problems with my 3-way Neverlube valves, and I'd appreciate the voice of experience before I start replacing parts.
First, on my return valve, I replaced the diverter with an Amazon brand part, and the shaft & lid o-rings with genuine Jandy parts. I have a leak between the body and the lid that didn't stop with new o-rings. The diverter does not sit in the body vertically, which seems to be due to a thicker diverter seal than the one I removed. Is this normal (and my old one was worn down) or is it an out-of-spec Amazon part? The diverter sits at an angle (see pic) and has to be pulled vertical with the lid when installing.
Second, on my suction valve, the actuator does not turn (or try to turn) when it is around freezing, either with the controller or using the switch manually. The diverter will turn manually with the handle, so it's not stuck. The actuator will try to turn back if it is on and the diverter is manually moved out of it's 'final' position. Could this be a problem with the microswitch or the gearing that I could repair, or do I just need to replace the whole actuator? Anyone seen it before?
Thanks for any help as always.
