Jandy valve actuator “clicking”
jberrymd
Active member
Jul 21, 2016
27
edmond, ok
Appears that the jandy actuator possibly has teeth broken off of gears. It will turn part way and then click as it attempts to continue turning. I can assist it and it will pick back up and the stop again after a little more movement.
What should I look for when troubleshooting the cause?
Is this something repairable?
I hope to not spend $200 on a new actuator. Thanks so much.
Reactions: jberrymd
You can try to repair it after you figure out what is wrong and chase parts or just get a new one like below (have installed many with no issues):
Likely made in the same factory.
