All,
I have an approximate 12k gallon pool, with Jandy Aqualink / iAqualink automation. I would like to be able to control the percentage of chlorine from the control panel and schedule it with the iAqualink web software. I have a couple of questions.
1) Will the UI be able to reduce the setting of the a Truclear to match the demand of my pool? (the cell if run at high usage will produce way more chlorine than my pool needs. (can you snip me a screen show of your iaqualink [aquapure] web portal and how it looks to reduce the demand? ) )
2) If I plug the Truclear into the serial interfaces on the Aqualink, does is just show up as an Aquapure?
3) How long do the Truclear cells last - if this is a 40k cell with 10k projected life- will it last 3x as long in a smaller pool (that changes the projected cost benefit in a good way.)
My other option is Hayward and the chlorinator translator; but I like the idea of adding in the Jandy if it's a reasonable quality piece of equipment.
-Adrian
-Adrian
