Moved from here.
Same issue what does rotate 180 meanHello all..My old Jandy SWG finally bit the dust in just 3 years! It was the 3rd unit we had installed in the previous 3 years. So we decided on this unit,the Hayward Salt and Swim 3. After installing it I am only getting a standing by and inadequate water flow lights. It will occasionally go to "generating chlorine" and then it goes right back to "inadequate water flow and stand by mode... When we first installed it we had 2 90 degree turns in the PVC and thought that was the problem so we replumbed it in a straight line from the filter. Still not working and still getting the same idiot lights lit! Very frustrating. I have been adding chlorine daily and I , quite honestly, had gotten very spoiled to having a perfectly clean and balanced pool on saltwater..I want a saltwater generator to work! Any one out there have this same issue and if so, how did you fix it? Thanks in advance for your help!
