Any suggestions would be greatly appreciated. Looked like I had a suction side leak that I thought was in the heat pump. The heat pump is dry inside no visible leaks, so it’s not the source. Is it possible to be leaking from the filter shell? From underneath it? How does that even happen? That’s the only surface area I can’t see. All fittings and multiport valve have no visible water leaking. Equipment is 4 years old. What do I do? Appreciate this forum and all your help in advance. Thanks!
