hello all,
I was wondering if you can kindly help me out with filter and spa pump replacements.
Current Specs:
42K gallon Pool. (POOL: two skimmers/1 Floor main drain, 3 returns) (SPA: one Floor drain, 8 jets, 2 returns)
jandy Filter pump 1.65HP single speed installed bout 2005ish ( looks like an old school Stealth. label states RPM: 3450, Volts 208-230/115)
Spa pump (3 inch outlet) 3.45HP single speed pump. (looks like an old school Stealth. label states label states RPM: 3450, Volts 208-230 only)
Jandy JXI heater 400K btu
CL Filter (580sq/ft)
Standard Air blower.
Linked to IQ-3.0.
two JVA's.
Looking to see which VS jandy pump recommendation to replace the Filter Pump and the spa pump? I'm getting some outrageous quotes in the NY tristate area. i'm pretty handy and tech savy (also have a plumber/pool service tech/electrician on standby to assist). Just want to make the right decision on pumps.
Many thanks for the advance help/advise/suggestions!
Regards.
S.P
Current Specs:
Linked to IQ-3.0.
two JVA's.
Regards.
S.P
