I have a Jandy PHPM1.5 PlusHP pump which I want to upgrade to a variable speed for energy savings and because it is getting old. I was looking at the Jandy VSPHP270JEP because it has the same exact dimensions and in a pinch I can interchange the two pumps without changing any plumbing. Pool Company A is telling me to instead go with the new Jandy VS FloPro VSFHP270 (or VSFHP165) because it is "better" (but not same dimensions so i won't be able to interchange with my old Jandy). Pool Company B is pushing a Hayward TriStar VS 900 because in their experience it is much easier to program and is more weatherproof then the Jandy . Again the Hayward does not have same dimensions as my old Jandy.
My question is should I stick to my guns and insist on Jandy VSPHP270JEP for interchangeability or go with Jandy VS FloPro VSFHP270 or Hayward TriStar VS 900 because these are truly better pumps. Is the Hayward easier to program and more weather proof than the Jandy ?
Any input or experience would be much appreciated. Thank you!
