- Jul 10, 2012
- 54
- Plaster
- Jandy Aquapure 1400
I have a Jandy PLC1400 & Jandy iAqualink system which were both installed in March as part of a pool remodel. I’ve adjusted salt to 3000 ppm and used a new Taylor K-1766 to verify my levels. The Jandy believes my salt levels are at 3700 ppm as shown on the Jandy app & on the display at the equipment pad. Does anyone else have this type of issue?
Normally I’d ask to have the PLC1400 controller swapped out but I’ve already had a temp sensor and the board for the iAqualink swapped out and that hasn’t solved an issue with incorrect temp read-outs. Does the salinity sensor being off by 20+% matter?
