So i noticed that my pump wasn't moving the water that it usually does. Upon inspection, some debris must have gotten lodged between the diffuser and the impeller and now water flow is very low. I tried to find a replacement for my model number (PHPM1.5) but it appears they stopped making them, can't find them. The current motor is decent two speed but would like to move to a variable speed pump. I have the entire Jandy Automation so I'm trying to determine my best options for a 2HP replacement or magically a replacement part(s) to get this one working again. If I do replacement everything (pump/motor) with a new setup I would like to still be able to use my automation if possible. Let me know what you guys think. What is the going standard for reliable variable speed pump/motor combo that is easy to work on when needed.
