I posted this last year.
www.troublefreepool.com
I replaced the vent temp fuse and never had a problem. This year fired things up and had no issues the first day, but eventually got the same issue.
Checked continuity and the fuse is no good. While I look to get a new one what else can I do to check the system for the underlying issue of those fuses going.
I've seen other threads mention looking at the heat exchange and cleaning out the orifices. I can seem to find any instructions or details on how to access the heat exchange on my LXI. I also took off the vent top but nothing really to shop vac in there.
Thanks.
Jandy LXi - Fuse Link Fault
Ran my Heater for a good 15-20 hours this year. Recently getting the 'Fuse Link Fault' Error'. When I turn the heater on, the fan starts. A little while later it ignites and I can feel heat being exhausted off the top. 20-30s later it stops with that error. It then retries a number of times...
Thanks.
