Hi all,
I've been dealing with a leaky header now for 2 years and finally brought myself to attempt to fix it. I have a Jandy LG125 heater that was purchased by the previous homeowners so I know it's old but it works well (except for the leak).
My problem is with the 2in flange connected to the header on both sides. When I try to connect a male PVC fitting (w/ teflon paste) the connection won't hold from leaking and over time loosens with the summer heat, causing to leak more. On the attached parts diagram it shows an option for threaded iron pipe or non-threaded iron or copper pipe with the use of plastic sleves/gaskets. I don't have those pieces but would that be an alternative?
I want to avoid replacing the flange's as they are $150-200 but as a last resort it's cheaper than a new heater.
Thank you in advance!
Joe
Joe
