So, I have a Jandy JXi400 that works both for heating the pool and Spa. In the past I used to be able to use my mobile phone to set the pool and spa temp as well as turn on and off the heater. Recently, the thermometer that reads the pool water failed so I replaced it. Now after I replaced the low voltage thermometer that is not even close to the heater, I am only able to control the heater by physically turning on the heater with the pool or spa button (I know 1st world problems). The heater works fine when I turn it on and off manually. I'm able to , but I'm lazy and would like to control everything from my phone. Anyone else have this issue? I have the remote function turned on at the heater to remote-t-stat.
Thanks
Thanks
