Got my 400k Jandy heater hooked up today. Everything runs as expected minus one possible issue?
I installed a 3 way valve - and an Intermatic actuator. On the Intellicenter it's Valve B and I used circuit "Heater" as the option. Everything works just fine - I turn on the Heat mode - the valve moves - BUT - when I get to the desired heat - the actuator goes back to bypass the heater.
The Heater said 'Temp Fault' since the Spa temp was 102 when it shut off - but with no water circulating the water 'stuck' in the heater went up to 105.
Is this a concern or not a big deal?
Part B - the Pentair said the spa temp was 100 - the Jandy heater said 102. I tested the water with a temp gun and it was 100 - not sure if I can change the temp setting on the heater.
