Jandy JXi heater with Hayward Omnihub mystery
Works fine without automation.
In RTSTAT mode, always on regardless of setting on the Omnihub.
If I pull the wires from the Omnihub and just manually touch them together or pull them apart, the heater turns on/off properly.
If I leave the wires connected to the Omnihub and use a multimeter, I can verify that the relay is opening/closing properly.
So, individually the pieces are doing what they are supposed to do. But connected together, they don't work.
I am not sure what is supposed to be output on the fireman's terminals, but when you turn the heat on, what reading are you getting with the multimeter?
It sounds like the problem is in the OmniPL Configuration and not the JXI heater.
