- Sep 16, 2018
- 6
- Plaster
- Jandy Truclear / Ei
Hey Everyone, I have A JEP-R controller that is controlling my Jandy VS pump. It has been hooked up for 5 years. It is on a breaker that has tripped randomly and I always just turned it back on. The other day I turned the breaker back on and the JEP-R now reads “Fault - Pump not Connected”. I have check the cable connecting the pump and controller. I also swapped out the JEP-R at the recommendation of Jandy but still have the same issue. I checked the voltage and have 120 on each line and 240 across the two. I can’t figure out what the issue is. Any ideas or suggestions?
