I have a Jandy JEP-R Variable-Speed Pump Digital Controller attached to my Jandy Pro Series VS FloPro Variable Speed Pump HP1.65. Both installed around May/June 1016.
The buttons on the controller do not seem to be working. When the pump is running and I go to push either the estar or #2 button to change speeds, nothing happens. Same is true if you try the change the menu, increase/decrease the speed, turn it off/on, nothing. Right now it is just set in the off position. That happened after cutting power to it at the breaker. Problem is I can't even get it back on and running to cycle the water while I wait for a professional. Every now and then if you hit a button it'll work, like once. But then no more.
Issue seems to be the controller, because the pump appears to be working fine when the controller shows on and is running at a high or low speed. Also called Jandy today and they believe it is the controller. Said if I have a licensed pool technician they can walk them through the steps to check it with a volt meter, but they couldn't work with a home owner. I have a volt meter and was ready to go! :-(
Anyway, anybody know the process to check it, or solutions, or stores that accept electronic waste?!
Eug
I created a signature but not sure it saved correctly. We'll see as soon as I press enter.
Eug
