Out of nowhere our brand new Jandy heat pump won’t run. I know the system is at least partially receiving the call for the heater since the pump speed increases when I turn the heater on with our handheld remote.
Since hooking up the remote I never looked at the display but it is on and this is what it is displaying.
A few immediate points and questions:
1) It’s absolutely under warranty so if my simple tinkering doesn’t work we will call for service.
2) is this the normal display code when the heater should be on and controlled by the handheld remote?
3) water is sitting in the bottom, I assume that shouldn’t be an issue since it’s open on top but felt it doesn’t hurt to mention.
4) how do I go back to controlling with the display and not the remote? I’ve read through the manual but I may have missed it.
5) everything else with the pool is functioning as normal, but the heater won’t run in spa or pool mode
