Howdy!
I broke down my Jandy DEV-60 for the first time to clean and recharge it and came across a bit of a hurdle with the outlet tube o-ring. The one that was on there looked warped so I thought it would be best to replace it. After an extensive internet search, I came across part number R0792000. It arrived and when I installed it I went to put the manifold back in place and it pushed the o-ring out of the groove on the outlet tube, not letting it slide down. I then decided to call Jandy support and they informed me that I ordered the incorrect part for the job and said I needed part number R0358000, which is a series of o-rings for the Jandy DEV60. That came and I installed the o-ring and, once again, the manifold would not slide down past the o-ring, pushing it out of the groove on the outlet tube. I applied silicone lubricant to the o-ring both times. Any advice or insight would be greatly appreciated! As a first-time pool owner, I can say the folks on this site have been amazing and super helpful! I hope to one day have enough pool knowledge to pay it forward!
On a side note/question. My pool has been sitting stagnant for about 3 days while I figure out the o-ring drama. Anything I should be concerned about there?
Thank y'all!
Thank y'all!
