My plan for winter was to keep the pump running, vacuum as needed, and add chlorine and acid by hand. I turned the Jandy SWG down to 0%, since I see no option in iAqualink to just turn it off. After a while, it showed "Low salt" but I wasn't worried because I'd ramp everything back up in the spring. Now it's showing error 144, which seems just mean really low salt. Is this a problem? Do I need to go ahead and add salt?
The manual says they sell a Spool Piece to replace the SWG in winter. Should I get this?
edit: Wow, it's over $100 for essentially a piece of plumbing: Amazon.com : Zodiac SP3P 3-Port Spool Piece and Cleaning Replacement Kit for Zodiac PureLink Water Purification System : Swimming Pool Chlorine Alternatives : Garden & Outdoor
Anyone rig their own dummy spool?
