Hello,
I am in the process of adding a Stenner pump to inject chlorine into my return. I want to use the AquaLink to run the pump via a relay. I plan on wiring an outlet to the relay and plugging the pump into that outlet. I think I can then set my AquaLink to run the pump for a set number of hours per day to inject the desired amount of chlorine into the return.
I have a total of 8 relays.
I have 1 relay that is not in use.
There is one relay that is connected to the control board at the Solar Pump position that has low voltage wire attached to it.
There are a total of 5 relays that are plugged into the control board in the following positions: PMP, Aux 1, Aux 2, Aux 3, and Aux 4.
PMP is attached to a relay that seems to be wired to the pump
Aux1 looks like it is attached to the Polaris pump
Aux2 is attached to the blower
Aux3 and Aux4 are attached to the Spa and Pool Lights
I have a relay being used as a terminal connection for some reason (the top left relay in the second picture below). It is not plugged in.
The next position available to plug in a relay on the board is Aux 5. However, when I look at the iAquaLink web app (Menu > System Setup > Label Aux) the next Aux available to name is Aux6. Aux5 is already labeled Deck Jets. Please see picture below for current Aux Labels.
Where should I plug in the relay?
Am I correct that I should be able to label the new Aux relay "Chlorine Injector" and use the Schedule feature to have it come on when the pump is running and run for a set number of hours?
Thanks!
Thanks!
