Can't wait for an update picture!There is so much funk in the pool that running the filter at 3-3400 causes me to have to backwash every hour or so. The water doesn’t look nearly as bad as that earlier pic however lol.
I just went to backwash even though the gauge didn’t indicate the need.
I think Naughty by Nature said it best, "You down with P.O.P? Yeah you know me". Something like thatFWIW, I've noticed my filter hasn't changed measurably during SLAM, but that there still seems to be things to backwash too. My gauge seems to adjust appropriately at other times (like jumping up when my pump is priming or if I adjust the rpm of my pump) leading me to think the gauge is good, but for some reason the gunk doesn't seem to raise the PSI.
My SLAM thread has some of my similar experiences, where the pool water didn't change significantly. It seemed like it just had to get over some kind of hump, because recently it's been changing by leaps and doing as it's supposed to. It could just be a matter of patience. Vacuuming to waste might be helpful, too, or using a robot vac like I did (although if there are rocks down there I might not send the robot in yet.)
Agreed 100%I would think you would need to backwash more often on low speed, but I do not have a VSP so I don't really know. I know when I run mine on low it seems to catch a lot more stuff.
The pressure gauge tells the storyWell I had no idea! I thought it would be the opposite way. Hopefully the speeds I have set now are working well. I’ll mess around with backwashes and try to figure out how often it needs to happen if the gauge isn’t an indicator at low speed.
