Not a whole lot of updates,
Probably going to get a lot more rain so hopefully my pool refills some.
I have been checking my water level mark, and have lost no water since turning off the system.
I checked FC earlier and it had dropped to 4 after rain/harsh sun, added 3gals - i slowly walked around the whole pool and splashed it out in the middle, then brushed the entire thing to help it move.
I got the diving board off, but the base... is an issue. The metal bolts inside are either totally disintegrated and crumbled like paper (never really saw anything like that), or so rusted and fused together that it just WONT come off. In addition, it seems to be held on some other way because it. will. not. budge. at. all. There is only one actual bolt left that has fused itself down, the rest fell apart, so I feel like it should wiggle at least.
My pool AND filter arrived - I wasn't expecting filter until Monday - so if it stops raining maybe we can do something there. I find it funny I decided to order these items 1 night before this happens
even if there is a leak in a pipe somewhere, I think that the pump isn't safe (it was like 2943823095 degrees and had a sewage like smell coming from it), and I think from what I've read that filter is really undersized. I believe it is only 17 inches and 100lb of sand. Plus, the crazy leaks it has.
Problem being the equipment pad is almost non existent - it's so tiny
So my plan so far is:
-Keep up with the FC as usual but start brushing a lot more until I can get the pump on. I was a little bummed out earlier (okay a lot I was almost crying on the phone with my mom), and let the FC get away from me down to 4.
-Install new pump, filter, pvc.
-HOPE HOPE HOPE that maybe my filter had sprung another leak and I was losing more water then previous days
-Try to turn on the system with the skimmer off as originally and see if I lose water.
-If I don't, open the skimmer.
-If I do, well, figure out if we can fix it.
-If it only happens when the skimmer valve is on, maybe close skimmer until next year and just run on main drain. Is there any harm, other then having to brush more, and cleanup taking longer?
-Start drinking
-Start drinking
