Issue with Hayward AquaRite SWG generating chlorine with no water flow
While you go in circles with them, do you have a DVM or access to one from a friend? Just check the resistance between the two pins on the flow switch cable with the pump off. 99% sure it will show a short. Pass that info on to the confused support line.
It has a small RJ11 connector so no way I can get test leads in there. I would have to cut and splice the cable to test I think.
