So here is the issue. I have just replaced my Easy Touch Mobile remote (version 1 ?) that came with pool install in 2005 with I9 outdoor panel. Remote finally died and I replaced with a new old stock indoor hard wired control panel (version 2 I believe) that I purchased in a sealed package off ebay. Installed and hardwired and fired up and it picked up my data and settings from the I9 memory and all appeared to work well. Only issue is that it does not see, nor did it add the Inteliflo 4x160 info to the screen. When you look for the pump screen it does not identify the Intelliflo pump nor pump data like my remote used to, (I.E speed, watts used, rpm settings for equipment speeds etc.) . Pump functions are normal, timer works, speeds that it had for spa, pool, solar etc are functional I just don't have data nor am I able to change speeds/set speeds as before. Any ideas? Thanks in advance
