Is this “The Mark?”
Any hints on how to best get 15 lbs of stabilizer to dissolve, other than the sock-in-front-of-skimmer idea I saw in an old thread?
I’m thinking about using a 10gal bucket & hot water from the kitchen to help dissolve it in solution.
I use a hair net as a skimmer sock.
I put about a pound in one of those nets, tie it closed and place it in my skimmer. It dissolves about a pound per day. There’s no real quick way that I’m aware of to get CYA to dissolve quickly. Plus, a slow rise is better because you don’t really want to overshoot your goal.
Reactions: stretchphoto
I used to use old socks but changed to ladies knee-high stocking.. Not for me, but to add CYA.. :mrgreen:
The knee highs act as their own cord. And when I add them in front of a running return and come back 10 minutes later I can squeeze them and get massive amount of CYA to dissolve in the water. Do that a couple of times and you are done.
Using old socks took me all day, using knee-highs takes me about half an hour.
Dangle the sock in front of a return and run your pump 24/7 at a high speed.
Squeeze the sock occasionally and it will release a lot of stabilizer.
If any stabilizer ends up on the pool floor brush it around with your pool broom until it dissolves.
Just gave it a squeeze. Amazing.
I also do the knee high and squeeze trick. Still a PIA (when you have little patience, such as myself :LOL:), but gets the job done!
