Hopefully that was just leftover lubricant & general gunk.
Increased cya & maintaining a little lower ph will assist in reducing csi
You can also consider adding borates to assist & help prevent scaling of your swcg.
www.google.com
You can play around with the numbers to see what would result in a lower csi by hitting the csi overview card in
PoolMath
Frequent cleaning of your cell with acid will reduce its lifespan so its best to manage the water to reduce/eliminate the need to aggressively clean the cell.
Why do you have such a high ch?
Are you adding calcium/calcium comtaining products?
What’s the ch of your fill water?
Your current ch is manageable but you don’t really need to go much higher.
