I add chlorine 4 times per day. The first day I was trying to maintain 10 ppm but it dropped too quickly during the day. Yesterday and today I go all the way to 20ppm and the lowest it has dropped was to 12ppm.
TA 140
PH 7.5 when I started SLAM
CYA 20
CH 180
FC 15
CC 0.5
overnight FC drop test has been 1 or under all nights and I'm vacuuming and brushing daily.
30-40 CYA is what is recommended in the SLAM directions:
SLAMing an outdoor pool is most effective when CYA is around 30 to 40. Below 30 you lose too much chlorine to sunlight.
I would bump it up to 30 or 40, then keep your FC at 12 or 16 respectively for the remainder. Nothing to really do now to drop your chlorine as it should quickly reduce due to burnoff from the sun and algae, but no sense in going over SLAM level in your future chlorine adds.
