Is this algae or pollen
Fugazi
80
Saint Augustine Fl
My Chlorine level was normal and FC was 6 and combined chlorine is 0 and PH was 7.6
But the pool was green tint after a rain.
My pool is black plaster so hard to tell what color the pool water is other than cloudy.
But my pool filter is green that comes off with a hose
Algae or pollen?
6 FC
0 CC
Cya 50
TA 60
Calcium 350
PH 7.6
The FC never went below 3 I have been keeping it a little lower than normal because I got this dolphin robot and it recommended 5
I usually kept it at 7
I went ahead and slammed it and will take a reading tonight and check tomorrow for loss.
No reason to run lower FC because of the robot. You have CYA in the water. Your active chlorine is in the tenths of a ppm. Well below what they state (there FC range is with 0 CYA).
It’s been about 2 weeks that I have kept it at around 5 I check the pool every other day and the lowest it was was around 2-3
Normally I kept it at 7
I will keep it there going forward.
I did slam it with lvl 20 which is what the website pool math says ...
