So, it appears you have visible algae that were not sure if it’s dead or alive. You did pass the OCLT technically BUT there was something consuming the chlorine as you saw a drop. IMHO I personally would focus on a SLAM rather than focusing on the filter. The algae in my eyes appears to be the root cause of your issues. Now do you drain some to lower the salt level first? I’ll let others chime in here as I don’t really ever look at salt so I’m not sure if that’s high or what. ?? I would get your CYA level up there to around 40ppm then follow the SLAM Process procedure.
