- Jul 21, 2013
- 66,784
- Plaster
- Pentair Intellichlor IC-60
The SWG will not “react” when in the low salt state.I tried everything, disabled or enable on easy touch pannel, 0% on panel with disabled and enabled, no matter what I do, the SWG itself remains at 80% with solid red light low salt - off. Only way to make the SWG "react" to do something is if a long press the less button, it then goes to 40% and goes back to 80 1 minutes later....
Set the EasyTouch to 0% with SWG enabled and if it comes alive during a salinity check the ET will set it to 0%.
